OMC Fluid Substitutes?
chavez
Can any guide me to some substitutes for the following Lubes/fluids :
1) Triple-Guard Greese
2) Gasket Sealing Compound
3) Adhesive M
4) Moly Lube
5) Nut lock
Thanks
Travis
SKEETR
Re: OMC Fluid Substitutes?
-triple guard grease- not sure if there is a substitute, this stuff is great well worth the $
-gasket seal-permatex aviation I have used permatex high tack around exhaust for temp rating but it is some stringy stuff.
The other three are what they are I am sure you could use whatever moly or marine adhesive you chose. Loctite red and blue for nuts and screws
