omc fuel pump
DavidD
Considering the old pre VRO pumps are Pulse operated and yes I know the VRO pumps are to. Will they function correctly upside down or on there side?
boobie
Re: omc fuel pump
I know I'll probably get some heat from this, but I can't see why they won't.
DavidD
Re: omc fuel pump
Me neither just checking for reasons why it wouldnt. It was alot easier to do a vro conversion putting it on upside down.
kodibass
Re: omc fuel pump
I have mounted them both ways and lying flat after tapping a nipple on the back for a pulse hose and never had a issue.
F_R
Re: omc fuel pump
In some pumps, mounting it upside down puts the outlet check valve at the bottom of the pumping chamber. That means that an air bubble can collect above the level of the check valve, which is commonly called "vapor lock". Mounting it right side up puts the outlet at the top of the chamber so the air is expelled before the fuel rises to the outlet, purging the pump and keeping it purged as it runs.
OK, ok, I know there are pumps out there that are running upside down. But if they are giving hard to diagnose fuel shortage problems, don't ignore the facts.
johnson89
Re: omc fuel pump
P1010003a fuel pump.jpg,,,here's mine upside down,been this way for 2 years now 90hp
DavidD
Re: omc fuel pump
That is the exact way i just connected mine
