Challenger84
- Joined
- May 9, 2010
- 341
My engine is an 88' omc gm 305 5.0L v8 w/ cobra out-drive.
So today I took off my new starter to readjust it.
Got new bolts for it and reinstalled starter.
Changed the oil and I was ready to take her out for the first time!
BAD news..
My friend that was helping me installed the battery cables on the WRONG terminals!!
neg to pos.
pos to neg
He said there were sparks coming off the terminals of the battery when he did this.(after I tried to crank the engine over)
I tried to crank the engine over while the cables were switched and NOTHING happened.
I took another look at the battery connection and noticed it on backwards!
Switch it back to the correct terminals try to crank it up and Nadda!!
I tested with a test light to see if the starter was getting power and ground ,it is.
My dash doesn't light up as well when I turn the key.
It seems that nothing is getting power.
My trim works though.It goes up and down.
My blower and bilge pump doesn't get any power as well.
My question is there a fuse or something that might be blown due to incorrect battery connection?
Does anyone have any suggestions on what it might be?
All the hard work put into the boat and today was my scheduled day for the first splash off. This really sucks.
I know it's not his fault.
It's all my fault that I didn't double check the connection and maybe I should have did it myself..
Thanks for looking. and all the help.
-Cheers
Andy
BAD news..
neg to pos.
pos to neg
-Cheers
Andy
