Re: OMC ignition coil question...external resistor
it was right off of the charge and when measuring the batter it was just positive to negative posts on the battery...and I know the coil has an external resistor...The coil has 5 wires going to it...2 lighter gauge which, one to the negative and one to the positive which run while the engine is running correct? there are 2 heavier gauge wires (one to the negative and positive) which are used when cranking the engine over right?the fifth wire is just the trigger wire from the distributor...so i guess what my question is; what should the voltage be when measuring the positive of the coil and just an engine ground, while the engine is running? I have an external resistor so I thought it should only be about 9v at the coil with the engine running? But im getting ~14v
