Re: OMC intermediate question
Thanks, for the reply.
Yes, according to the service manual, I agree, it should be two bearings.
BUT, this one, only has the one. No marks on the shaft where there was another one. Also, the housing, where the race is, is ummmmmmm not really tapered, but not round, the upper part, where the oil is installed, is higher than the rest of it. There is NO way you could get another race in there.
I'm pulling what little hair I have out.
I will check the upper housing, thanks,
I have another out drive, I took the intermediate shaft out of it as well, it is the older style, with two greased bearings, one flat roller, and one ball bearing. But it's upper gear set seems to be in very good condition. I would put it on the outdrive and put it back together, if I could figgure out the shaft and bearing deal....
Thanks.
