Trapper John
- Joined
- Aug 5, 2007
- 7
Background: '92 Seaswirl w/5.8l/351 Ford and OMC sterndrive.
Symtom:
Boat runs for 10-15 minutes @1000 rpm through no-wake zone. Within 5 minutes after hitting 2500 rpm, engine begins to run rough until rpms drop to 750 - then she stalls out. Temp gage says 120. Problem appears to be thermal because a 5 minute rest will allow a restart, but failure reoccurs more rapidly.
Starter will not turn over immediately after stallout. After rest interval, ignition occurs normally. Alternator output checks out. Batteries check out. New coil, distributor, and ignition module this season.
Suspicions: water pump impeller, faulty shift interrupt switch and/or ESA, or both. Any advice? Thanks!
Symtom:
