imported_Nathan_
- Joined
- Nov 21, 2003
- 26
Time to change out the fluid in the old 89' OMC King Cobra 5.7<br /><br />Ive got the OMC book here in front of me and and in the book they tell you to pop the top cap loose and change the o-ring then put it back onto the upper side of the drive but don't tighten it down.. <br />From there I drain the fluid from the bottom plug.<br />Once its all drained I need to fill it back up but I have to do it from the bottom and fill it upwards..<br />My question is that, I don't have a pump to fill the unit up from the bottom. I do understand that we need to fill from the bottom slowly to get out all the air pockets. What if I was to fill from the top then close it up move the drive up then back down then recheck the fluid ? I'm wondering if the movement would help get the air out. By filling it from the bottom up is this done because of the air pockets ?<br /><br /><br />Thanks guys<br />Nathan
