OMC lower unit gear housings.
subcrx
Looks like my 5.7liter OMC Cobra lower unit gear housing has to be replaced because the carrier bearing wont seal deep inside, its just too pitted. A new housing runs 1800 bucks. So im going to have to go with a used one. Ive found several but dont know if it will fit. The GLM one seems to have a screen when mine does not. And are the outboard ones compatible? Some say v4, v6, 4.3l. 2.3 and so on. Here is pictures of both sides of my cobra.
subcrx
Re: OMC lower unit gear housings.
There are lots on ebay
BLC
I have a freind that has a brand new one, but Im not sure what omc leg it is for. I was going to use it as a spare for my 2.3L cobra, but the area where the prop shaft seal goes was too big. I will try to find out what it is for and let you know if you want.
subcrx
Yeah does it have the 4 bolts that hold the carrier bearing in? and do you know the diameter of housing where the prop shaft is?
subcrx
better yet a picture of the top and side would be perfect
