a.d.mobile
- Joined
- Jul 15, 2002
- 326
Well i have a 50 classic ser A196055 1986? and it is a classic this belongs to a friend? i guess if he was a good friend he would have a omc ok ok. here we go first it had carb problems rebuilt carbs found bad pump diaphrams. he ran boat 6 times ran great. then i get the dreaded call runs like $hirt. checked spark 1 cyl not fireing taped switch box and wamo spark. put a CDI after world box on good spark on crank plus at idle on hose remove wires 1 at a time and she is a welder. take it to the lake and what a dog like it is running on 2 cyl pulled new plugs for inspection #1 good #2 all wet no signs of burnt fuel #3 good and #4 same a 2. motor has 125psi in all holes. tore carbs down again every thing is good in there. how does that triger work fires 2 cyl at a time? then the other 2? sorry this is a book. thanks A.D.
