OK, I knew I'd have to put some money in this boat. Mechanic says compression is very good on all cylinders and it runs great, but small amount of water showed up in the oil. He thinks it's risers or manifolds but can't be sure without tear-down. He also says he can't be sure whether water has been in oil long enough to damage bearings etc.
The boat is a '94 with OMC '93 outdrive that he claims is in very good shape. The boat has been in saltwater most of its life. It's a new boat to me, I've never had it in the water yet.
The question is whether to just do risers and/or manifolds and hope the engine goes for awhile yet OR put a whole new motor in it.
I guess this hinges on the condition of the rod/main bearings which is unknown. Is there an easy way to figure this out?
Is it just not worth the risk of an engine failure, so I should just go new?
Any and all advice is greatly appreciated.
