I have a 1977 OMC I/O that i have used for years without problems. I always use type C oil in the out drive because of the electric shift this model has. Last week the out drive acted like it slipped out of gear. I disassembled the out drive unit and found nothing wrong. I went as far as taking the reverse coil out of the lower unit. Is there a splined shaft in the lower unit somewhere??? I have checked the wires going to the out drive and they have power, i checked both forward and reverse wires. I will check the coils as soon as i get a hold of a volt meter but my feeling is they will be O.K. both coils would not go bad at the same time. Can someone point me in the right direction i'm able to do the work and can not afford to take it to the boat shop.
Mike
Mike
