DRIVE: OMC COBRA DRIVE, RATIO 1.5: 1, SERIAL NUMBER: T00789440, MODEL# 3868158/OMC COBRA, 5.8L, 8 CYL, GAS, MULTI PORT FUEL INJECTIONENGINE: MODEL NUMBER: 5.8 MIE; SERIAL NUMBER: 1275976
Out-drive will not come off: Mechanic (Boat-Tree) tear down to inspect out-drive seal and bellows due to collision with sand bar resulting in water leak and engine not running. Heated and soaked with solvent to release no result. I will be taking over teardown as they will have to cut off casing to continue now my expense.
Out-drive was removed two years ago and since has been on lift when not in use, last owner.
How can I get the Out-drive off?
