drexton311
- Joined
- Jul 19, 2016
- 51
Moved here for better visibility...How do I delete the other post?
1988 OMC Chevy 5.0 with Cobra I/O
I am chasing power steering issues and have not run across a post that is like what I am experiencing. Maybe a little help from the knowledgeable group please. All tests were done on muffs on a warm motor, sterndrive lowered of course.
So, I have determined that my power steering has a few issues.
First issue: I noticed a light sheen on the lake water and had heard that this may be the result of a bad oil cooler. Upon inspection, I found that the cooler is leaking water; no problem, a new cooler is ordered and inbound. (Found a new one on ebay for $99.00, replaces OMC P/N 983849) I guess this solves my issue of constantly having water in the bilge!
Second issue: the power steering actuator leaks from what appears to be the fittings (high pressure into the ram and low pressure heading to the cooler) It seems that it only leaks when I run the steering to full blocked position in one direction, the other direction, it does nothing. I did tighten the fittings, they were not too incredibly loose and I understand that I am not supposed to steer lock to lock, and I do not, but I was testing the system for leaks when I realized what was happening and since the PS reservoir does not empty out as quickly as I thought, I am guessing that’s because I do not normally steer lock to lock. Also, when I greased the ram through the fitting, it expanded the cylinder, which I though was weird. In addition, the steering feels like it is pulsing when I turn the wheel.
Third issue: simultaneously when steering to full blocked position, the power steering pump stops spinning which allows the belt to forcefully “slide” on the stationary pulley causing a squealing noise. Now I have adjusted the belt tension, so this happens even with what appears to be good belt tension. I cannot find any other PS leaks.
So my questions:
Is it normal for a steering actuator to shed oil when under a load as I put it under?
What is the pulsing feeling I get when steering? How do I correct it?
What is going on with the pump, I assume that is not normal?
Any help would be appreciated.
Thanks!
Josh
So my questions:
Thanks!
Josh
