OMC Prop
Roadrager50
I have a 1977 190 OMC where is a good place to find a new prop? Would it be better to have mine repaired? I have two aluminum and a bronze. The aluminum are three blade and the bronze is a four blade.
Texasmark
Re: OMC Prop
Scroll the forum down and look at the top....wala your answer on where to buy new. On what to do, your call.
steelespike
Re: OMC Prop
If you could get us the info needed in "read this first" at the top of the prop forum we can help figure a prop out.
If the props are from 77 a new prop may have better technology.
But to tell what size you need we'll need your wot rpm and gps speed with one of the props you have,
probably a 3 blade.
You could get one of the props repaired for the test run and if a change is needed you could keep it for a spare.
