Re: omc running temp
Ron,<br />OK, I know what drains your talikng about, thanks. The block is fairly new, but it won't hurt to drain it. <br />Lou,<br />I thought that housing would be a problem. That impeller change was too easy. When I went to replce the housing I couldn't get the new o-ring in place, like it was too small, so I re-used the old one. After assembling it I attached the hose and there was a little seapage coming from the housing. I'll pick up a pump kit and replace the housing. <br /><br />By the way Ron, the boat is DEFINATELY not for sale!!! <br />Put the esa module in and its shifting pretty nice. Just have to get it running cooler, which doesn't seem to be a problem, even if it needs risers and manifolds. <br />Other than that, just got to move the axle on the trailer before last pull out of the water, toungue weight too light.
