I put together the diode setup, im gunna install it tomorrow, Ill see if it works. Right now I know I have twelve volts going into the esa, but no power at all going into the switches. Would you say my esa is shot or is it possible when I install this circuit it will magically come to life.
The diode fix does work. I put it on mine when I installed the Pertronix. I have since installed the newer ESA and removed the fix. I later had an intermitent problem with my ESA. Finally found a bad wire (connector) between the ESA and the coil. Ran a bypass wire around the connector. Now all is good. Something to check for if it still doesn't work. I would hate to know I had to do without my ESA. Tough times at the dock for sure.
