Re: omc shift interrupter and overdrive switch
I have a 1977 orrion open bow with a OMC 140 engine #990236e1. The wiring from the shift interrupt switch and the over drive switch have been cut. Where do these 2 microswitches connect to? Also where does the shift assembly mount on the engine? As seen in this similar set up by the white arrow i do not have that black plug.
I hope this is alright.
jonnybska, go to crowley marine.
click sterndrive,OMC sterndrive,up above you will see product support,click on it.
OMC sterndrives,Mechanical shift.
This list will tell you everything about the shift interrupter and the micro switches, What they do and how to set them.I used this when I converted to a full mechanical shift this year,READ IT, It works!
I bought a complete conversion OMC interuptern package on Ebay.
I still have the instructions on wiring it up if you need them.
I can copy them and send them to you.
Beef
By the way isn't a 1977 stringer an electric shift?
