Hi,<br />I have a 1988 2.3 liter omc cobra and I've had the usual problems with the switches, cables, and gear sets. Now however, I'm having a problem with the engine cutting out while under power, generally after it runs for a while. If I remove the switch with the roller (the one that stops the motor for shifting and tends to get stuck while going to neutral)from it's bracket the boat runs fine. The other switch is much more expensive (I think it is the overide switch) so before I change it do you think that could be it or would the electronic shift box be the more likely culprit? I hate to switch them both out as it would be close to $200
