So I just had the transom shift cable replaced on my 1992 Seaswirl 230 SWL. It has a carbed 350 indmar engine with a cobra outdrive. I took it to a mechanic here that supposedly specializes in Cobras. I picked up the boat from him the other day and put it in the water. It shifts into gear just fine, but as soon as I try to advance the throttle past high idle in fwd gear, the boat stalls. Reverse works fine. I called the mechanic and he had me adjust the trunnion a couple of turns back towards the stern and fwd gear started working fine, but as soon as I would try and advance the throttle in reverse past high idle it would stall. The mechanic now says that I need to have my shift interrupt replaced with an electronic one that kills the motor for 5 seconds to solve my problem. Is this correct? or does the cable need some different/more adjustments? Thanks in advance for any replies.
