Sorry for the long post in advance. I have a 1992 Seaswirl 230 SWL with an OMC cobra outdrive. Just had the transom shift cable replaced as well as the ESA (switched to electronic). Right after the electronic ESA was installed I went to launch the boat. Boat engaged in reverse fine and I backed the boat off the trailer. After I tried to put the boat back into neutral, the lever on the control unit broke and I could not get the boat out of neutral. The button underneath the handle is just hanging there and nothing happens when you pull it up to try and move the lever. The handle is currently stuck in neutral and I cannot seem to find how to disconnect the handle from the actual control unit. I have posted pictures of the actual lever, but am not sure if this helps at all? What should I do from here? Any advice will be greatly appreciated. I would like to try and fix this myself before I result in taking it to a mechanic. Thanks!
PS-Sorry for the low quality pics
