Re: OMC Spitfire ignition conversion
I'm not used to getting response so quickly, Yes I do have the King Cobra w/cone clutch matched with a 350 GM. The hump on the top of the upper gear housing is how I am identifing it. I did not know about the cable difference between the cone and dog clutch. My cable enters the outdrive on the port side. This combination must have been as rare as the Spitfire itself. I agree with the comment about the lack of support and access to parts, but, I truely have been amazed at the durability of this outdrive. I've owned this boat for the past 10 yrs and would not change anything about it except for the spitfire system. To be honest with you all, 10 years of almost flawless performance from this spitfire EEM system. If not for the lack of replacement parts and mechanics experienced working on this system, I may have replaced in kind.
Rick, funny, I did track down "blowho" and had a couple good conversations with him, Great you could help a local guy out! Hes from Kent and I'm from West Seattle.
Rodbolt, you mentioned that the cone clutch did not need a shift interrupt but all my research shows that the Spitfire module performed the functions of the ESA but where triggered by a single interrupt switch mounted on the shift bracket(no overstroke switch) So in my application I assume I need the existing interupt switch. My Seloc manual shows multiple wiring schematics for different setups. I have rewired mine following the schematic for a GMC 5.7 litre LE powerplant equip with a Standard distributor minus the ESA module and my new distributor has 2 wires, 1 going to each side of the coil. I was going to try using like this, because like you said the cone clutch shift so much easier than the dog. If this setup does not allow smooth shifting then I'm ready to install a ESA module.
Another question. I have read some info requiring the bypassing of the resistor wire when converting to an electronic ignition from a points setup to supply constant 12v to the coil. Do you think this would apply to my conversion from the spitfire? It is already a electronic system?
Thanks for all your input, If any of you or someone you know has done this conversion please keep the info coming. Joe
