Omc stern drive..how to remove shift cable?!
ereid74
I have the shift cable removed from inside but i can't get it pulled through the intermediate housing? I have a BAD bearing that was making my 3.8l die out once the engine/bearing warmed up. I had metal shavings in the lower unit, once i pulled the drain plug....im unsure if i should tackle this job myself or just take it to somebody (replacing bearings and seals)? nevertheless i still need to get the out drive away from the intermediate housing!
ereid74
Re: Omc stern drive..how to remove shift cable?!
i sprayed the the cable from both sides of the intermediate housing...how can I remove the cable through the lower unit?
superbenk
You need to get a manual.
ereid74
I have a seloc manual but its pretty vague, just wondering if any experienced members could give me their .10 cents, Thank you!
sea wolf
Uh, what drive are we talking about here?
southkogs
I have an electric shift, so it's completely different: My manual includes your drive year, and I think this is the correct section for yours:
Hope that helps.
