I am stuck with a 1970's OMC Stern-drive I/O. It is either a 225 or 245 H.P. model. The engine is a Chevy 307 V8. I just hate this thing. It is on my father's boat 300 miles away. I don't really have anyone to ask about the normal operation of the drive. On the side of the lower unit, there are "pivot" covers (part # 0313264). Under them is a paper gasket, a plate, and an O-ring. the covers themselves are home plate (baseball) shaped with four bolts holding them in place. Cooling water flows behind the plates, thus all the gasket and O-ring. My question is if water is supposed to spray out of the plates, similar to an outboard motor? Mine simply could be leaking, but I don't know if this is normal? Are they supposed to **** a steady directional stream like an outboard showing you the water pump is working well? Or, are they not supposed to leak at all? Thanks.
