I have a 1977 23 ft. cruiser with an OMC 235 hp 351W I/O, was a gift from my father in law. The block was cracked, replaced it. One and only time I put it in the water it ran extremely hot. (I had been running it in the yard on the hose). Had water in the oil afterward. I took loose the raw water supply hose from the outdrive. With the drive submersed in a horse trough, no water was being pumped up.Bad impeller, right? Figured I had blown a head gasket or worse, so I tore it down to the head (didn't see a blown gasket), carefully inspected the block, had the heads magnafluxed. Got new gaskets for the heads, exhaust and intake, put it back together and it runs like a charm. Tore the outdrive down to replace the impeller, and it's brand new looking, definitley not my pumping problem. What else can it be? Bad seal, etc? Any input is greatly appreciated.
