omc stern drive
notinbig
how is the shift cable released from the lower unit, the boat side has a nut 3/4, thats easy. the outter side has a 4 inch slide, my problem is that the slide moves with the nut?!?!?!<br />88 larson 4.3 with an omc cobra
Lark40
Re: omc stern drive
Amazing timing! I was just fighting with mine last night. Did finally get it off.<br /><br />I had to loosen the 3/4" nut by starting it with a wrench and then turning the entire pivot unit around it to further unscrew it.
notinbig
Re: omc stern drive
DID YOU LEAVE THE SLIDE AND SHIFT LEVER ASSEMBELED OR DID YOU TAKE IT ALL OFF DOWN TO THE BRASS SLIDE.?
BigBabyLou
Re: omc stern drive
If you want to remove the shift cable from the pivot housing, you NEED TO loosen and remove the slide.<br />Your service manual should have the correct instructions step by step. I believe it says to remove the retaining bolt on the slide and the metal retainer (by unscrewing it c/c).<br /><br />I too had to hold the 3/4" nut with a wrench and turn the whole pivot housing. :) <br /><br />Hope this helps.<br />Lou
notinbig
Re: omc stern drive
thanks for the help its out and at the shop for adjustment back by the weekend!<br /> :cool:
