OMC sterndrive lubrication question
jhorus
I bought a 1990 VIP Victory 1960 with OMC stern drive late last summer. I'm in the process of getting it ready for the summer, and putting grease in the only grease zerk I see. It's on the starboard side, close to the hull.
The shop manual suggests there's more greasing to be done inside the drive? (2 U joints?) I am not that mechanically inclined, and was hoping not to have to take anything off. Does the starboard zerk grease those U joints, too, or do I really have to take the stern drive off? (or maybe just the cover I'm hoping?)
Btw, I ran through a whole tube of grease, and haven't yet heard the distinctive "crackling" you get when old grease is forced out. Does the zerk connect to something that holds that much grease and it just hasn't been refilled in a while? Where is the spot where it'll be forced out?
zbnutcase
Re: OMC sterndrive lubrication question
No, you have to remove the drive to grease the u-joints, the fitting you describe just greases the gimbal bearing. And you will want to remove it anyway to clean out the whole tube of grease you pumped into the bellows as the gimbal bearing is not a sealed unit! 'nutcase
Gary H NC
Lou C
http://support.crowleymarine.com/entries/113074-omc-cobra-complete-outdrive-removal
http://support.crowleymarine.com/entries/114108-omc-cobra-complete-outdrive-installation
http://support.crowleymarine.com/entries/113068-omc-cobra-outdrive-lubricant-filling
Here are some relevant links with factory procedures for maintaining the Cobra....the only thing you can do without taking off the drive is to grease the gimble bearing...it's very important esp if you don't know the maintenance history of the boat to have the sterndrive removed...bellows checked for water...gimble checked for smooth operation and greased...ujoints checked for too much play and greased...driveshaft splines greased...driveshaft seal in the upper unit checked for leaks... engine alignment checked....these are things that should be done yearly in my opinion....Sterndrives are high maintenance machines and if you neglect them it will cost you...
I do this...winterization....fluid change...in the fall...then in the spring...install a new impeller in the drive...grease gimble...ujoints...shaft splines...check alignment.....install drive...run engine...check all fluids again...do a tune up...then go boating....
MRS
What Lou C put is excellent info. and crowley has alot of omc stuff that others do not. I needed pivot housing bolts and inserts (heli-coils) they had them and saved my a** and my vacation got it going and life and wife were happy.:D
Mine omc 190 candia 4.3 (1986)
jhorus
Thanks for the replies :)
Now y'all got me worried about that extra grease. Where is it likely sitting right now, and how long can it be there before doing "harm" of some sort? I wasn't planning on taking my boat to the shop for a while, and I don't think I have the tools/time/patience to take off the stern drive myself. :)
How would it normally get cleaned out if I had done it correctly, and there was just a little bit of excess grease? Does it get expelled during normal running?
