Serf27
- Joined
- Aug 23, 2018
- 167
I have diagnosed and tested all cables and done all cable and shift adapter housing adjustments.
I measured drag/resistance on main shift cables with a fish scale.
Both were under 2.5lb.
I set the over stroke switch per the manual.
Start engine
Rotate shift arm until in full reverse
Adjust reverse plate/bracket to depress over stroke switch
Rotate shift to full forward and adjust forward plate to depress over stroke switch.
The over stroke switch and ESA switch is working as it should when measured with a voltmeter.
Idle has been adjusted to 600 RPM.
When I move the V arm surrounding the ESA switch, the engine doesn’t stumble as the manual says it should.
I have read about fuses for the system, but I see no fuses listed in the manual.
All this comes from a lower case swap.
With my old lower case, I had no issues shifting on the water, with this case, it is hard to shift out of gear under load in water.
My new propeller is also larger.
I see the ESA drops the engine to 450 RPM. I thought 600 RPM would suffice to shift out of gear. I haven’t tried it with the lower idle under load, only on land.
But since all the switches measure properly, is the ESA module bad?
Start engine
