OMC Stringer outdrive shear pins?
Larry E
Are there shear pins in the system OMC Stringer outdrive that can shear if the outdrive while in the down position hits something?
Larry E
Howard Sterndrive
Re: OMC Stringer outdrive shear pins?
no, there is a clutch that should slip, but don't count on it.
There are shear pins on the horizontal shaft that coupler the tilt motor to the worm gear.
Larry E
If the motor wont lift the outdrive could those pins be sheared? If so how do I get to them?
looking at the outdrive from back of boat. on port side, small football shaped cover. if the motor is not turning, you could have a bum motor.
Howard Sterndrive
Motor runs at a higher RPM then before when it was all working well. It sounds normal when I am putting the drive down.
sounds like theclutch might be slipping
put the drive up halfway,
stand on the lower unit
should hold you
Larry E
should hold you
Right on. I changed the clutch pack and all is well again.
Thanks
Larry E
