undrh2o
- Joined
- Nov 14, 2011
- 41
1976 OMC Electric shift. I replaced the bad tilt motor and after a few uses heard a noise...now the worm gear shaft is hanging out the back of the housing where the plug/circlip used to go.
I had a mechanic tell me there was an aftermarket bracket available years ago to fix this problem by being mounted to the side of the housing. I found the above image. It was bent into an "L" shape and the over the work gear housing plug to keep it from popping out.
Yes, I would like to replace the OMC with another outdrive but this is mounted to a 50' Stardust Cruiser and just to trailer the boat is around $1000.
If anyone has info as to where I can find this bracket or a part number I would be most appreciative.
I will snap a couple of pics and post in the next few days.
TIA ~ Rob
