OMC Tach rests on 1100 RMP
G DANE
Working on my boat I discovered that the OMC tach i got with my used Evinrude outboard, rests on 1100 rpm when lying in box. It this a sign of a defective tach ??
rmpenton
Re: OMC Tach rests on 1100 RMP
it reads the last rpms it was at when the power was cut off.if you apply power to it and it stays at that rpm then yes its defective,but if it reads 0 when power is applied then its fine
G DANE
Thanks - i didnt know.<br /><br />I tried to shake it a little, but it didnt move much :) Hope its still okay<br /><br />If I try to connect it to battery and it goes to zero, i will know it is OK ?
