OMC Tilt Gear
impman
I have a 73 Imp with an OMC 225 , the tilt raises and lowers but I t will not stay up and I think It should lock down...right? Is there suppose to be some kind of spring in the clutch of the tilt mmotor? and where can I start to look as why it will not lock in down possition>> any help would be greatly appriciated
wire2
Re: OMC Tilt Gear
There's a cupped washer spring on the end of a stack of clutch plates in the reducer housing. They tend to slip when water gets past the shaft seal and mixes with the motor oil in there.
impman
Re: OMC Tilt Gear
On the outer end of the clutch or behind it? when I removed it , I pulled the cover off and sterted to remove a sreies of washers then the clutch plates all the way back to a clip at the farthest inside section. So this sping, is it inside the long gear coming from the inside of the boat.. thanks for the info
aerwin
Re: OMC Tilt Gear
thereis no "lock down", the clutch pack keeps the outdrive down. if the clutch pack is not working correctly then it won't keep it down. the outdrive will creep up a little with use and when the drive is in reverse and if you gun the engine it will pull it out of the water, be carefull in reverse!!!! the long shaft you are talking about is from the tilt motor and has a spring which is the hammer coupler. please get a manual to get the right repair procedure on the clutch pack
wire2
Re: OMC Tilt Gear
Mine is an '84 but I expect yours is similar;
On the cover end of the shaft is a circlip, then a washer about 1?" diameter, then 3 cupped washers 2-3/4" dia. stacked, (that's the spring), then the clutch pack.
If you can overdrive the clutch by lifting or pushing the outdrive by hand, it's slipping.
impman
Re: OMC Tilt Gear
thanks so much for the help. I think I get it. Ive been trying to find a manual locally for this boat , but its old and not easy to come by.Ill have more questions in the future im sure
whywhyzed
Banned
Re: OMC Tilt Gear
64-86 OMC manual available here at iboats - probably in your local library too - every town I have ever lived in has had it.
aerwin
Re: OMC Tilt Gear
the manual for the boat, if it exists, will not help you, you need the manual for the omc 800 drive package, boat brand is irrelevent to drive package, Clymer, Seloc or an OMC manual are what you need, OMC manual is the best. the other two will help in most situations
Lyndy
Re: OMC Tilt Gear
I do not think he has an 800 series drive. The 400/800 did not show up for another 4-5 years. Based on the year of the boat it is likely to be a High Profile Stringer. Similar to the picture below. Ebay has a number of manuals available and Ken Cook has reprints of OMC Manuals. Based on the year of the boat the Outdrive should be 1972-1974.
Ken Cook:
http://www.kencook.com/evinrudejohnsonmanuals/index.cfm?fuseaction=boats.main&manufactor=omc
OMC Parts Catalogue
http://stores.ebay.com/SEARAYMAN13_...ATALOG_W0QQcolZ4QQdirZ1QQfsubZ5QQftidZ2QQtZkm
OMC Service Manuals
http://stores.ebay.com/SEARAYMAN13_...-1985_W0QQcolZ4QQdirZ1QQfsubZ11QQftidZ2QQtZkm
Do not suggest Third Party Manuals. Been there done that.
The 400 and 800 are similar looking. Below is a picture of the upper portion of a 400
Hope this helps
