OMC Tilt issue
joedrifter
Hello everyone,
I am new and just purchased an 87 Bayliner Trophy. It has a GM 5.0l and the power tilt was working when we purchased it. However, I had to replace the drive unit with the help of another iboats member and everything is cool. However, I was able to tilt the drive down to test it and not the drive is not going back up. The solenoids are clicking and I am getting power out to the green and blue wires going to the pump housing. Not sure what to check. Any suggestions would be great.
Thanks
Joe
Re: OMC Tilt issue
Ayuh,.... Welcome Aboard,....
My guesses are Bad ground, or Bad motor...
joedrifter
Re: OMC Tilt issue
Ok I will check both now and I am also going to put a charger on the older batteries and hook up a jump box and try it again.
Thanks
Joe
joedrifter
Re: OMC Tilt issue
Hey guys,
Just an FYI. All I needed was a hammer to whack it! The motor is going bad.
Thanks Again,
Joe
