OMC tilt mechanism plug?
drrm123
i have a 1981 3.8 OMC 800 stringer i'm replacing the seals & gaskets on. the plug that covers the worm gear above tilt clutch wont come out, any suggestions? sprayed with penetrating oil last night also tried tapping with brass hammer?
chiefalen
Re: OMC tilt mechanism plug?
You got the triangle cover off?
And the insides of the tilt clutch housing out?
You took off the truarc snap ring around the brass plug off?
All thats left is the worm gear and plug?
Turn the worm gear should pop it out.
It don't go into the housing it comes out.
chiefalen
You got a manual?
I take the guts out of the housing first.
Than i push that freekin plug out from the inside. bye turning the spur gear which turns the worm gear that push's that plug out.
Your diagram don't even show the snap ring.
You took it off?
drrm123
There was not a snap ring. Have a seloc manual, looking for a original OMC still. I got it out I actually put outdrive back on and let it up and down a couple of time and it popped out, changed o-ring and put back together,now for test drive later today, thanks again.
chiefalen
I got the seloc right here in front of me.
This is what the front says on mine.
3400--Right hand corner
Omc Stern Drives
1964-86 Repair Manual
Page 8-9
Figure 2- lower right hand corner.
Yours is what year?
Mine is 1986.
Maybe you didn't have one.
Glad you got it out.
I tuned mine with the motor also once to pop it out.
drrm123
chiefalen the one i have is pictured on page 8-10 picture 3 with the triangle cover and that's the plug i was trying to get out, thanks again.
