Warkmeister
- Joined
- Feb 4, 2022
- 7
Hello again. As im making my way through the various systems on this boat (1987 spectrum sportsman 1900 with OMC 2.3) the trim had been working until tonight. I lowered the outdrive to prepare to remove it, and in positioning it on a wood block, I noticed the trim stopped going up. I have the Seloc manual for the boat, and started to follow the troubleshooting guide. The hydraulic motor runs seemingly fine in both directions. I do recall hearing some fine bubbling the last time the drive went down fully tonight. I opened the manual release valve to extend the cylinders in order to check fluid level, but they won’t extend. I disconnected them from the drive, and still can’t get them to extend by pulling them out. Am I understanding these correctly, that opening the release valve would let the fluid freely move from reservoir to cylinders to extend them, or is it the other way around?
