Boat:<br />88 17' Seaswirl: Tempo Sport<br />4.3 GM<br />OMC Cobra<br /><br />All stock, not sure of the throttle brand.<br />One trim switch on the throttle handle, no "trailer lift" button, I use my the one trim button for everything and just listen when it tops out.<br /><br />Question:<br />Wondering if this boat should have some type of upper trim limiter on it when running?<br /><br />I usually run the trim based on speed and boat attitude, trim down coming out of the hole and trim it up until she sits flat.<br /><br />The other day my son asked me to try to throw a "rooster tail" while we were moving so I started running the trim up a little more than I usually do, got some "tail
" but didn't want to do to much as I figured it put the u-joints in a bind. I also have a trim gauge (and it still works to) seems to run WOT well with the needle about middle of the gauge. However there is a lot (about 75%) of the top part of the gauge that is available, maybe I can trim up more than I have and pick up another couple hundred RPM. Although she runs around 4000 - 4300 now depending on weight in the boat.<br /><br />Does anyone know if there should be limiter on this unit?<br /><br />Regards
