OMC trim pump and ram indentification?
YmeHP
Hello, I need to replace the trim pump and both trim rams cylinders) and bolt between the two on a 89' OMC Cobra outdrive bolted to a Ford 460. Can someone help me with part numbers and a place to order thos from?
a70eliminator
Re: OMC trim pump and ram indentification?
Here's your part numbers good luck!
985660 cylinder ram (2)
986278 manifold & pump assy. (1)
913812 pivot pin (1)
I'm thinking N/A your probably looking at locating used pieces.
