Hi
Part number 3854397 lift pump seal kit for the valve body. It typically has 14 O rings and a filter. The pump is round and has no reservoir pump tank below (see my photos. They show pump, diagram of pump, and my 1995 Four Winns 200 Horizon in mint shape)
https://www.iboats.com/ideabook/ron3033-photos
This style pump is used in many, many boats in my area. It seems kind of crazy that for the sake of a few worn O rings one must buy a new $800 pump plus new retrofit hydraulic lines and labor.
This part is used in OMC and Volvo Penta same #3854397 for kit.
My outdrive sags down about 2 to 3 inches in about 4 days. I do not know whether it is the lift pistons or the pump? AND I do not know how to determine which is ths issue?? Suggestions How to Determine?? (no external leaks that I can see on pistons, or at pump.. mind you it is hard to get even near it..yikes.)
The colored O ring set in photos are the new improved bidirectional kit for the lift pistons, for your info.
Any one know where to get the kit and how to tell if my pump or pistons are the issue.
Thank you any suggestions appreciated
ron3033
ron3033
