OMC trim sender price gouging
a70eliminator
I'm really ticked off at the dealers who hoard up OMC parts, and triple the price, guys like me can't afford to get an their boat running. What I don't understand is that dealers are driving these parts up yet the value of an OMC is going down nobody wants them. Check this letter of reply from go2marine regarding the trim sender.
Hello, the OMC part number is 984748.This part went obsolete several weeks ago. Stone and Sons in Texas has them in stock. They have raised the price to $275.00. We sold them for $114.00 until two months ago.
HT32BSX115
Re: OMC trim sender price gouging
I hate to say this, but in response to the previous threads that asked what's wrong with buying a used OMC powered boat.......
THE COMPANY IS OUT OF BUSINESS! YOU ARE AT THE (current) PART SUPPLIERS MERCY!
Does anyone need ADDITIONAL clarification?
I feel for you having had an OMC stern-drive in my Four Winns Liberator.
Mine had some parts that are basically not available at ANY price!!
I'm sure you can find a trim sender at a lower price but you'll most likely have to do a lot of internet shopping to get one probably.
I had a lot of the same problems.
Good luck,
Rick
Ayuh,..............
And I'm the Bad Man for telling potential buyers to Run away for the deal............:rolleyes:
Don S
It's called supply and demand.............
Big demand, no supply. Want to guess the results?
Same with OMC 460 Couplers, and manifolds, and ..............
I catch it just like Bondo and several others.
HT32BSX115
Yeah...I did the same thing and found the same 3 sources.
I would call them first thing in the morning and make the order!!
alaska_av8r
Almost sounds profitable to pick up salvage OMC drives and sell them just for parts....you could probably sell the parts and make enough money to replace it with a different drive....
wire2
Are you talking about the sender on the hydraulic engine ram?
The only working part on it is a $5 potentiometer, with a plastic lever. I'm sure it can be fabricated easily.
Or watch eBay. I recently sold a good pump, hoses, 2 rams (1 with sender) for $150
wire2
As a matter of fact, this summer I sold a very clean '84 stringer outdrive for $2k locally. Then bought a 2 month old alpha outdrive for $1100, then all the other parts, coupler, Y pipe, inner & outer transom, steering cyl, gimble, rams, trim pump, all hardware (except engine) for $900.
