I have an OMC Cobra 3.0 (GM) I just put a head gasket on. I read some of the other threads about setting the valve lash, witch I understand. What I am having trouble with is how do I rotate the engine a half of a turn with it still in the boat? I have tried taking the spark plugs out to keep it from compressing. If I try to "bump" it with the starter its not accurate. There is no nut on the carankshaft pulley and if there was I would not be able to get to it because of the engine mount. Any tips or advice would be greatly appriciated. As soon as I get the valves adjusted I'll be back on the water.
