Striper500
- Joined
- Nov 20, 2005
- 52
I currently own a 1992 90Hp Johnson that has all original gauges on the dash. Late last year the volt meter stopped functioning properly. For some reason, once the key is turned or the boat is running for that matter, the needle gets pinned at the highest level which is 19 (I believe) I pulled the cluster of gauges out of the center console to see if there may be a short somewhere, and it didn't appear as though there was any. Everything also looked to be hooked up properly. Again, it was working all last year. Are there any areas that I can check to do some troubleshooting ? Any help would be appreciated.
