SILTHUNDER77
- Joined
- Jul 24, 2005
- 13
Is the water pump and impeller for an omc outdrive located in the upper assembly or lower?, and what do I need to do about changing it out? any drawings, diagrams would be helpful..<br />Also, is there a concern that the impeller could be broken off(pieces of it) and blocking or obstucting some part of the water flow system, causing overheating at higher rpm's..
