jgordon525
- Joined
- Apr 1, 2010
- 1
Hey all,
I am just finishing up repower of my old Wellcraft Nova 250XL from single OMC800 stringer to VP260A w/280PT drives (clamshell covering the actuators). Need to choose the first trial prop and since I have all the data needed to make the calculations I figured it might be an interesting challenge for all you experts out there. Really informative for the rest of us!
The boat:
79 Nova 25xl 25' and change 9.5' beam
Most of the Nova's had 2 260hp mercs / alpha/MR drives and would run 55-60 WOT. The dual engine boat weight 5200 lbs. Mine is the single engine version with a taller freeboard. Lets say 4200 lbs(?).
Previous power
260HP rebuilt SBC
OMC 800 Stringer driver w 1.41 ratio
15 x 15 OMC prop
lost track of how deep the drive was set
WOT 4200 / 33 MPH (with no hesitation getting there)
3500rpm cruise / 26 MPH
Repowered
VP 260A SBC From donor boat. Compression and leak down are great.
VP 280PT 1.61 ratio
280 will swing a 16" diameter
I set up the drive depth so the cavitation plate +1/2" from the hull.
If I am making the same power...... what do you think a good prop is to start with?
Typical usage 4 adults and gear. 120 gallons fuel. Used offshore in Southern California. Hoping we can improve the cruise speed right out of the gate.
Will going to a 16" dia prop help? Since the OMC 800 stringer had no problem getting to WOT, I am guessing I could have pushed a 15 x 17". Now with the VP and 1.61 ratio can I get away with going to 17" pitch and the 16" diameter? How do you calculate slip?
Of course I am expecting to fine tune from the first prop. But since I have a lot of info to work with (enough?) I am betting one of you guys might be able to get REAL close on the first shot. Will keep everyone posted on the results.
Thanks for your input!
Joel
HB, CA
The boat:
Previous power
260HP rebuilt SBC
15 x 15 OMC prop
Repowered
VP 280PT 1.61 ratio
Joel
HB, CA
