hello..my wife just bought me a motorguide maxi 26 two bank on board charger for my trolling batteries. i have one cranking battery with a separate on board trickle charger for it.i have two 12 volt trolling batteries wired in series to run my 24 volt trolling motor.my question is do i have to remove the jumper wire between the 2 trolling batteries before charging them or can i charge them in series. also im thinking about adding an isolator to charge the trolling batteries as im running. can you give me some pros and cons. thanks in advance ....john50
