I searched this topic and got a lot of great info about on board chargers. I have one more question that I did not see an answer to.
I have a dual battery (not deep cell) set up on my boat with a Perko switch with 1/2/all/off settings. I want to add a 2 bank on board charger mainly to be used as a maintainer to keep the batteries charged when the boat is stored over the winter and sometimes for 2 or 3 weeks at a time in the summer. When I am using the boat I will often have the radio on without the engine running for a few hours at a time. This is where my question comes in, If I am parked at my dock with the radio (or anything else) on can I have the charger plugged in to shore power at the same time to keep the batteries from being drained? Or should the Perko Switch be in the OFF position while charging to avoid any problems with it messing up the alternator or any other electronics on the boat? I will usually switch to just one battery while doing this so if the battery does drain I can switch to the other battery and still start the boat. I hate to put the charging burden on the alternator when/if I switch back to the drained battery so I want to get an on-board charger to take the load when I have 120v AC power available.
With this in mind would it be best for me to get a dual bank charger that has automatic charging/maintaining based on the needs of the battery? Or just stick with a low amperage maintainer?
