Alfgeiger1
- Joined
- Jul 19, 2025
- 9
Sea Ray 2001 SD240 with 5.0L EFI GM 305 motor, on crank do not get fuel to throttle body from the injectors See no spray, hear the fuel pump. I can get it to start with starter fluid and then it runs fine, drove it for 30 mins on water, exercised idle to WOT, fuel spray to throttle body is perfect so thinking fuel pump is ok. Also assuming if it runs so well once started that the ECM is ok, is it just a sensor that is telling the ECM not to send gas to throttle body on start? If so which one? Don’t have a computer reader so can’t get any codes. I can go out there right now and the fuel filter is full, crank, no spray. Anyone have any ideas? THANKS!!!
