? on force 50 powerhead replacement
skbry
Overheated my powerhead and I'm in the process of replacement.
There's a vertical divider plate on the motor leg that meets up with the powerhead seperating the exhaust and the water pickup tube. Is there suppose to be a seal in there for that? Is it common to have exhaust blow by in the section of the motor leg were the water tube/water pump is? It seems like this may have been part of the overheat problem, theres a lot of sand and oil in that section.
Thanks for your help
Bryan
jerryjerry05
Re: ? on force 50 powerhead replacement
Year?Serial# ? They made a lot of different motors.
Pics will help too.
skbry
1985-507x5a, I check the parts microfich but its not listed and I'm not sure if its a intergral part of another.
tater76
No paper seal on the thin divider, but it came from the factory with a sealant on it like high temp rtv. That is what I used on my 50, and 55. Clean the surfaces well, put a generous bead on it, put the base paper seal on, and drop the powerhead on.
