? on Installing setback plate
eugene1e
Im going to be Installing an Outboard setback plate on a inboard to outboard conversion Im doning and have a ? the setback plate is 2 feet and 9 inches long where should the cavition plate be in refrence to the bottom of the boat I was told there was a forumala for this <br /><br /> Thanks
JB
Re: ? on Installing setback plate
The anti-ventilation plate should be even with the bottom of the boat. With the setback you may gain a little by raising it an inch for each 4" of setback from the transom, but this is fine tuning and should involve testing and experimentation.
eugene1e
Here are pic of the set back plate<br /> http://www.shareaproject.com/imageUpload.php?i=3669 <br /> http://www.shareaproject.com/imageUpload.php?i=3670 <br /> http://www.shareaproject.com/imageUpload.php?i=3671 <br /> http://www.shareaproject.com/imageUpload.php?i=3672 <br /> http://www.shareaproject.com/imageUpload.php?i=3673 <br /> http://www.shareaproject.com/imageUpload.php?i=3674 <br /> http://www.shareaproject.com/imageUpload.php?i=3675 <br /> http://www.shareaproject.com/imageUpload.php?i=3676 <br /> http://www.shareaproject.com/imageUpload.php?i=3677 <br /><br />As you can tell its none adjustable so should I just mount it with the anti-ventilation plate even with the bottom are move it higher on the transom the plate is 2 foot 9 inch's<br />with this forumala I can raise it 8.25 inchs from the bottom
surlyjoe
thats a beast of a mount! its gonna do funny things to your wieght distribution moving all that weight from inside the boat that far out the back. have you thought about shortening it?
JB
I take it back. That monstrosity is a bracket, not a setback plate.<br /><br />You will need to experiment with the height of the AV plate. You want the AV plate right at the water surface when the boat is on plane; not out of the water, but right at the surface.<br /><br />Don't mean to offend, but that thing (and the boat after it is mounted) is uuuuuugleeeee.<br /><br />Good luck. :)
eugene1e
ok I have a 20 ft bayliner cabin cruiser that had an inboard the inboard was taking out now I want to convert it to outboard I would really like to do it with out cuting the hull down and reglassing a splash well becouse I would like to keep the fish box so what would you guys recamend
Purduebarry
OH MY GAUD! Where in the heck did you get this thing, from a barge? You might want to consider some trim tabs while your at it. How big of a boat are you mounting it too?
Purduebarry
Can you have it cut down, it's too long. Check out a setback plate on line. The motor will be wwwaaayy back and all the weight with it. You need to get the motor closer to the boat. This will look like a motor mounted to a swim platform. What are you doing to the transom to support this rig?
eugene1e
Im looking for ideas I really dont want to cut the transom becouse I would lose my fish box
tommays
I usually see those on really big boats (how big a boat are you using) the leverage is going to huge and I would think on a small boat when not moving would really put the motor much to deep in the water to the point of getting water in the cylinders <br /><br />Look at it this way on my 20’ boat 1” of boat position on the trailer makes about 200# difference in tongue weight<br /><br />Tommays
eugene1e
Ok what would you guys suggest I have a 20 ft bayliner liberty that had a inboard in it but now it has nothing.<br />I have a 175 mercury outboard that I want to put on this boat <br />Now I have this setback bracket <br />I have the mean and ability to Cut the transom and reglass a spash plate But would really love to keep the fish box that on the back of the boat What should I do If I cut the brackit dead in half would I still be able to raise my motor for Tailoring <br /><br />Thanks for all your help :confused: :confused: :confused: :confused: :confused:
Purduebarry
I think it can be done but not with this thing. Maybe you can compromise. Cut the back and build a platform, build in your fishbox. Sticking that motor way back there may be risky and the boat might not handle well. Why take a chance, do all the work and not have it run right. I dunno, I'd go to plan B.
BLU LUNCH
Take cruise over to www.wellcraftv20.com there are a bunch of guys running brackets, there is a wealth of info on brackets posted on the forums..
BLU LUNCH
The conversion you are going to do is common from I/O to O/B. You going to free up space in the boat and add stablity and floatation, they seal-up air tight. Post pictures and check-out the link above those guys will help you out.....
epresutti
eugene1e,<br /><br />This is a link to the gil brackets that I am familiar with. They do a lot of different things to the handling of the boat they also provide floatation.<br /><br /> Gil Brackets <br /><br />Hope this helps.<br /><br />Peace.<br /><br />Ed.
