?? on replacing the deck on a 77 MFG Gypsy
Blackstorm
I have started the deck(s) removal and have reached the hull. It appears that there were two prevoius attempts at repairs both involving 3/4 plywood that went in untreated. The foam was soaked and the two strings were rotted out ( I expected this) and I am prepared to replace the stringers. Here are my questions so far.
The stringers were glassed in half heartedly how do I remove the glass back to the hull. (A) Grind it out and with what or (B) cut them or (C) Something else
When the foam was removed down the center of the boat there are sections of half round fiberglass (2-2 1/2" across) that appear to channel water to the bilge area. Do I want to keep this in place or remove, there are open sections which I think are used to collect and channel water to the bildge. I will take pictures tomorrow as I am digially challenged my wife will help me load them up.
On the above waterline sections of the boat there were several holes put in it that I no longer need is it acceptable to use auto body (Marglass) to patch the holes or do I need to epoxy these like the floor.
I will limit my first post to these three questions. BTW I love these forums and all of the information they possess.
Thanks
Glynn
