Once again another Prop Question
rs1lollie
I have a ? on 3 blade vs 4 blade props, I currently use a 3 blade 14.25x21 prop for cursing, and I switch to a 3 blade 14.25x19 prop for water sports, I was looking at a 4 blade prop and it says to go 2 lower from your current pitch, so my question is if I run a 21 pitch I should drop down to a 19 pitch, is the 19 pitch 4 blade going to act like the 3 blade 19 pitch??? I'm looking for a in between prop so I don't have to change the prop all the time.
1990 Maxum 1800
7'2" beam
1900 net weight
1.84:1 alpha 1 gear ratio
3.0 mercrusier 181c.d.i.
135hp
max rpm 4400-4800
around 4800rpms @ 45mph w/ 21pitch
around 5200rpms @ 37mph w/19pitch
cribber
Re: Once again another Prop Question
I have a very similar setup with mt Glastron GT-185 with the 3.0l Volvo and get very similar WOT numbers from my 14.25x21 and 14.25X19. I picked up a SS 4 blade Stiletto Bay Pro II that is 14x20 and WOT rpm hits 4600 at 40 mph. I gained a quicker holeshot, lower plane speed, and better low to mid-range control. Since putting it on, I haven't used my other two props at all this season. I picked mine up on sale here at Iboats.
rs1lollie
Thanks cribber, so is there a big differance in preformance between an aluminum prop and a stainless steel prop of the same size and pitch??
Dhadley
You really can't compare an aluminum prop to a Bay Pro II, it's not fair to the aluminum prop. The BP II is an amazing prop and will work well on sterndrives.
rs1lollie
I would like to stay with an aluminum prop, The SS props are too expensive for what I do.
rs1lollie
just bought a Mercury Alpha 4 blade 14x20 Aluminum Propeller, will put it on and try it out this next weekend.
hwsiii
Lollie, you must have some major blade geometry differences between your 21" and your 19" pitch aluminum props, because your 21" pitch is showing only a 13% prop slip and your 19" pitch is showing a 27% prop slip and that is backwards to the normal way that different pitch changes in the same make and model of props works.
Prop Slip
H
rs1lollie
I dont know if this makes a diff. they are 2 different mfg. 21 is a mich. wheel and the 19 is an old style turning point.
rs1lollie
Just got back from the lake , Man its like I have a new boat!!! This Mercury Alpha 4 14x20 4 blade prop is Awesome!!! running 42mph at 4800 rpms, great hole shot, and planes very fast. Will have to try pulling a tube b4 summer is over and see what kind of performance the prop will give me. With the new prop on my steering is a lot easier to turn and with little torque steer at low no wake speed. :D:D:D
hwsiii
Lollie, it sounds like you piked the right prop for your boat.
H
