I fixed my previous problem by replacing the fuel pump. It now runs WOT at about 5500. I also changed the plugs, plug wires and one coil that was cracked. It runs great except when I pull away from the dock and slowly start to accelerate. I sounds and feels as if it is running on 2 cylinders instead of all four. When I push the throttle to get on a plane, it runs smooth on all four, all the way to WOT. Any suggestions? By the way, I'm running a 40:1 ratio on fuel/oil at the advice of my mechanic. Could that be a factor?
Thanks, Ted
Thanks, Ted
